of: Delete an unnecessary check before the function call “of_node_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The of_node_put() function tests whether its argument is NULL
and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Rob Herring
 drivers/of/base.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/of/base.c b/drivers/of/base.c
index 7792266..cb255a0 100644
--- a/drivers/of/base.c
+++ b/drivers/of/base.c
@@ -1631,8 +1631,7 @@ static int __of_parse_phandle_with_args(const struct device_node *np,
  err:
-	if (it.node)
-		of_node_put(it.node);
+	of_node_put(it.node);
 	return rc;
BtrLinux
Privacy Overview
