ocfs2: Use BUG_ON
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no
side-effects to allow a definition of BUG_ON that drops the code completely.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ disable unlikely @ expression E,f; @@
  if (<... f(...) ...>) { BUG(); }
- if (unlikely(E)) { BUG(); }
+ BUG_ON(E);
@@ expression E,f; @@
- if (E) { BUG(); }
+ BUG_ON(E);
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Mark Fasheh
 fs/ocfs2/alloc.c   | 3 +--
 fs/ocfs2/journal.c | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/fs/ocfs2/alloc.c b/fs/ocfs2/alloc.c
index a268821..41f84c9 100644
--- a/fs/ocfs2/alloc.c
+++ b/fs/ocfs2/alloc.c
@@ -1029,8 +1029,7 @@ static void ocfs2_rotate_leaf(struct ocfs2_extent_list *el,
 	BUG_ON(!next_free);
 	/* The tree code before us didn't allow enough room in the leaf. */
-	if (el->l_next_free_rec == el->l_count && !has_empty)
-		BUG();
+	BUG_ON(el->l_next_free_rec == el->l_count && !has_empty);
 	 * The easiest way to approach this is to just remove the
diff --git a/fs/ocfs2/journal.c b/fs/ocfs2/journal.c
index bffd2d7..9698338 100644
--- a/fs/ocfs2/journal.c
+++ b/fs/ocfs2/journal.c
@@ -717,8 +717,7 @@ int ocfs2_journal_load(struct ocfs2_journal *journal, int local)
 	mlog_entry_void();
-	if (!journal)
-		BUG();
+	BUG_ON(!journal);
 	osb = journal->j_osb;
BtrLinux
Privacy Overview
