nilfs2: constify nilfs_sc_operations structures
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The nilfs_sc_operations structures are never modified, so declare them
as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Ryusuke Konishi
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 fs/nilfs2/segment.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/fs/nilfs2/segment.c b/fs/nilfs2/segment.c
index 4317f72..483e663 100644
--- a/fs/nilfs2/segment.c
+++ b/fs/nilfs2/segment.c
@@ -617,7 +617,7 @@ static void nilfs_write_file_node_binfo(struct nilfs_sc_info *sci,
 	*vblocknr = binfo->bi_v.bi_vblocknr;
-static struct nilfs_sc_operations nilfs_sc_file_ops = {
+static const struct nilfs_sc_operations nilfs_sc_file_ops = {
 	.collect_data = nilfs_collect_file_data,
 	.collect_node = nilfs_collect_file_node,
 	.collect_bmap = nilfs_collect_file_bmap,
@@ -666,7 +666,7 @@ static void nilfs_write_dat_node_binfo(struct nilfs_sc_info *sci,
 	*binfo_dat = binfo->bi_dat;
-static struct nilfs_sc_operations nilfs_sc_dat_ops = {
+static const struct nilfs_sc_operations nilfs_sc_dat_ops = {
 	.collect_data = nilfs_collect_dat_data,
 	.collect_bmap = nilfs_collect_dat_bmap,
@@ -674,7 +674,7 @@ static struct nilfs_sc_operations nilfs_sc_dat_ops = {
 	.write_node_binfo = nilfs_write_dat_node_binfo,
-static struct nilfs_sc_operations nilfs_sc_dsync_ops = {
+static const struct nilfs_sc_operations nilfs_sc_dsync_ops = {
 	.collect_node = NULL,
 	.collect_bmap = NULL,
@@ -1043,7 +1043,7 @@ static size_t nilfs_segctor_buffer_rest(struct nilfs_sc_info *sci)
 static int nilfs_segctor_scan_file(struct nilfs_sc_info *sci,
 				   struct inode *inode,
-				   struct nilfs_sc_operations *sc_ops)
+				   const struct nilfs_sc_operations *sc_ops)
 	LIST_HEAD(data_buffers);
 	LIST_HEAD(node_buffers);
@@ -1550,7 +1550,7 @@ nilfs_segctor_update_payload_blocknr(struct nilfs_sc_info *sci,
 	sector_t blocknr;
 	unsigned long nfinfo = segbuf->sb_sum.nfinfo;
 	unsigned long nblocks = 0, ndatablk = 0;
-	struct nilfs_sc_operations *sc_op = NULL;
+	const struct nilfs_sc_operations *sc_op = NULL;
 	struct nilfs_segsum_pointer ssp;
 	struct nilfs_finfo *finfo = NULL;
 	union nilfs_binfo binfo;
BtrLinux
Privacy Overview
