nfsd4: convert comma to semicolon
Author: Himangi Saraogi <himangi774@gmail.com>
Replace a comma between expression statements by a semicolon. This changes
the semantics of the code, but given the current indentation appears to be
what is intended.
A simplified version of the Coccinelle semantic patch that performs this
transformation is as follows:
@r@
expression e1,e2;
e1
e2;
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: J. Bruce Fields
fs/nfsd/nfs4callback.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/nfsd/nfs4callback.c b/fs/nfsd/nfs4callback.c
index 564d723..c393d6c 100644
--- a/fs/nfsd/nfs4callback.c
+++ b/fs/nfsd/nfs4callback.c
@@ -678,7 +678,7 @@ static int setup_callback_client(struct nfs4_client *clp, struct nfs4_cb_conn *c
(clp->cl_cred.cr_flavor >= RPC_AUTH_GSS_KRB5))
return -EINVAL;
args.client_name = clp->cl_cred.cr_principal;
- args.prognumber = conn->cb_prog,
+ args.prognumber = conn->cb_prog;
args.protocol = XPRT_TRANSPORT_TCP;
args.authflavor = clp->cl_cred.cr_flavor;
clp->cl_cb_ident = conn->cb_ident; |
return -EINVAL;
