fs/nfsd/nfs2acl.c | 12 ++++++++----
fs/nfsd/nfs3acl.c | 6 ++++--
fs/nfsd/nfs3xdr.c | 27 ++++++++++++++++++---------
fs/nfsd/nfsxdr.c | 15 ++++++++++-----
4 files changed, 40 insertions(+), 20 deletions(-)
diff --git a/fs/nfsd/nfs2acl.c b/fs/nfsd/nfs2acl.c
index 11c1fba..12b023a 100644
--- a/fs/nfsd/nfs2acl.c
+++ b/fs/nfsd/nfs2acl.c
@@ -182,7 +182,8 @@ static __be32 nfsacld_proc_access(struct svc_rqst *rqstp, struct nfsd3_accessarg
static int nfsaclsvc_decode_getaclargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_getaclargs *argp)
- if (!(p = nfs2svc_decode_fh(p, &argp->fh)))
+ p = nfs2svc_decode_fh(p, &argp->fh);
+ if (!p)
return 0;
argp->mask = ntohl(*p); p++;
@@ -197,7 +198,8 @@ static int nfsaclsvc_decode_setaclargs(struct svc_rqst *rqstp, __be32 *p,
unsigned int base;
int n;
+ if (!p)
return 0;
argp->mask = ntohl(*p++);
if (argp->mask & ~(NFS_ACL|NFS_ACLCNT|NFS_DFACL|NFS_DFACLCNT) ||
@@ -218,7 +220,8 @@ static int nfsaclsvc_decode_setaclargs(struct svc_rqst *rqstp, __be32 *p,
static int nfsaclsvc_decode_fhandleargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd_fhandle *argp)
+ if (!p)
return 0;
return xdr_argsize_check(rqstp, p);
@@ -226,7 +229,8 @@ static int nfsaclsvc_decode_fhandleargs(struct svc_rqst *rqstp, __be32 *p,
static int nfsaclsvc_decode_accessargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_accessargs *argp)
+ if (!p)
return 0;
argp->access = ntohl(*p++);
diff --git a/fs/nfsd/nfs3acl.c b/fs/nfsd/nfs3acl.c
index adc5f1b..2a514e2 100644
--- a/fs/nfsd/nfs3acl.c
+++ b/fs/nfsd/nfs3acl.c
@@ -128,7 +128,8 @@ out:
static int nfs3svc_decode_getaclargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_getaclargs *args)
- if (!(p = nfs3svc_decode_fh(p, &args->fh)))
+ p = nfs3svc_decode_fh(p, &args->fh);
+ if (!p)
return 0;
args->mask = ntohl(*p); p++;
@@ -143,7 +144,8 @@ static int nfs3svc_decode_setaclargs(struct svc_rqst *rqstp, __be32 *p,
unsigned int base;
int n;
+ if (!p)
return 0;
args->mask = ntohl(*p++);
if (args->mask & ~(NFS_ACL|NFS_ACLCNT|NFS_DFACL|NFS_DFACLCNT) ||
diff --git a/fs/nfsd/nfs3xdr.c b/fs/nfsd/nfs3xdr.c
index de6e39e..e6c01e8 100644
--- a/fs/nfsd/nfs3xdr.c
+++ b/fs/nfsd/nfs3xdr.c
@@ -278,7 +278,8 @@ void fill_post_wcc(struct svc_fh *fhp)
int
nfs3svc_decode_fhandle(struct svc_rqst *rqstp, __be32 *p, struct nfsd_fhandle *args)
- if (!(p = decode_fh(p, &args->fh)))
+ p = decode_fh(p, &args->fh);
+ if (!p)
return 0;
@@ -287,7 +288,8 @@ int
nfs3svc_decode_sattrargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_sattrargs *args)
+ if (!p)
return 0;
p = decode_sattr3(p, &args->attrs);
@@ -315,7 +317,8 @@ int
nfs3svc_decode_accessargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_accessargs *args)
+ if (!p)
return 0;
args->access = ntohl(*p++);
@@ -330,7 +333,8 @@ nfs3svc_decode_readargs(struct svc_rqst *rqstp, __be32 *p,
int v;
u32 max_blocksize = svc_max_payload(rqstp);
+ if (!p)
return 0;
p = xdr_decode_hyper(p, &args->offset);
@@ -360,7 +364,8 @@ nfs3svc_decode_writeargs(struct svc_rqst *rqstp, __be32 *p,
unsigned int len, v, hdr, dlen;
+ if (!p)
return 0;
@@ -535,7 +540,8 @@ int
nfs3svc_decode_readlinkargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_readlinkargs *args)
+ if (!p)
return 0;
args->buffer = page_address(*(rqstp->rq_next_page++));
@@ -558,7 +564,8 @@ int
nfs3svc_decode_readdirargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_readdirargs *args)
+ if (!p)
return 0;
p = xdr_decode_hyper(p, &args->cookie);
args->verf = p; p += 2;
@@ -580,7 +587,8 @@ nfs3svc_decode_readdirplusargs(struct svc_rqst *rqstp, __be32 *p,
int len;
+ if (!p)
return 0;
@@ -605,7 +613,8 @@ int
nfs3svc_decode_commitargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd3_commitargs *args)
+ if (!p)
return 0;
args->count = ntohl(*p++);
diff --git a/fs/nfsd/nfsxdr.c b/fs/nfsd/nfsxdr.c
index 9c769a4..1ac306b 100644
--- a/fs/nfsd/nfsxdr.c
+++ b/fs/nfsd/nfsxdr.c
@@ -214,7 +214,8 @@ nfssvc_decode_void(struct svc_rqst *rqstp, __be32 *p, void *dummy)
int
nfssvc_decode_fhandle(struct svc_rqst *rqstp, __be32 *p, struct nfsd_fhandle *args)
+ if (!p)
return 0;
@@ -248,7 +249,8 @@ nfssvc_decode_readargs(struct svc_rqst *rqstp, __be32 *p,
unsigned int len;
int v;
+ if (!p)
return 0;
args->offset = ntohl(*p++);
@@ -281,7 +283,8 @@ nfssvc_decode_writeargs(struct svc_rqst *rqstp, __be32 *p,
unsigned int len, hdr, dlen;
int v;
+ if (!p)
return 0;
p++; /* beginoffset */
@@ -355,7 +358,8 @@ nfssvc_decode_renameargs(struct svc_rqst *rqstp, __be32 *p,
int
nfssvc_decode_readlinkargs(struct svc_rqst *rqstp, __be32 *p, struct nfsd_readlinkargs *args)
+ if (!p)
return 0;
@@ -391,7 +395,8 @@ int
nfssvc_decode_readdirargs(struct svc_rqst *rqstp, __be32 *p,
struct nfsd_readdirargs *args)
+ if (!p)
return 0;
args->cookie = ntohl(*p++);
args->count = ntohl(*p++); |
