NFC: nxp-nci: constify nxp_nci_phy_ops structure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The only instance of a nxp_nci_phy_ops structure is never modified. Thus
the declaration of the structure and all references to the structure type
can be made const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Signed-off-by: Samuel Ortiz
drivers/nfc/nxp-nci/core.c | 3 ++-
drivers/nfc/nxp-nci/i2c.c | 2 +-
drivers/nfc/nxp-nci/nxp-nci.h | 5 +++--
3 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/nfc/nxp-nci/core.c b/drivers/nfc/nxp-nci/core.c
index 8979636..2e4b004 100644
--- a/drivers/nfc/nxp-nci/core.c
+++ b/drivers/nfc/nxp-nci/core.c
@@ -109,7 +109,8 @@ static struct nci_ops nxp_nci_ops = {
int nxp_nci_probe(void *phy_id, struct device *pdev,
- struct nxp_nci_phy_ops *phy_ops, unsigned int max_payload,
+ const struct nxp_nci_phy_ops *phy_ops,
+ unsigned int max_payload,
struct nci_dev **ndev)
struct nxp_nci_info *info;
diff --git a/drivers/nfc/nxp-nci/i2c.c b/drivers/nfc/nxp-nci/i2c.c
index fac80c6..df4333c 100644
--- a/drivers/nfc/nxp-nci/i2c.c
+++ b/drivers/nfc/nxp-nci/i2c.c
@@ -106,7 +106,7 @@ static int nxp_nci_i2c_write(void *phy_id, struct sk_buff *skb)
return r;
-static struct nxp_nci_phy_ops i2c_phy_ops = {
+static const struct nxp_nci_phy_ops i2c_phy_ops = {
.set_mode = nxp_nci_i2c_set_mode,
.write = nxp_nci_i2c_write,
diff --git a/drivers/nfc/nxp-nci/nxp-nci.h b/drivers/nfc/nxp-nci/nxp-nci.h
index f1fecc4..20408cb 100644
--- a/drivers/nfc/nxp-nci/nxp-nci.h
+++ b/drivers/nfc/nxp-nci/nxp-nci.h
@@ -68,7 +68,7 @@ struct nxp_nci_info {
enum nxp_nci_mode mode;
- struct nxp_nci_phy_ops *phy_ops;
+ const struct nxp_nci_phy_ops *phy_ops;
unsigned int max_payload;
struct mutex info_lock;
@@ -82,7 +82,8 @@ void nxp_nci_fw_recv_frame(struct nci_dev *ndev, struct sk_buff *skb);
void nxp_nci_fw_work_complete(struct nxp_nci_info *info, int result);
struct nci_dev **ndev);
void nxp_nci_remove(struct nci_dev *ndev); |
return r;
