NFC: Move the nfcwilink dereference below the NULL test
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Samuel Ortiz
drivers/nfc/nfcwilink.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/nfc/nfcwilink.c b/drivers/nfc/nfcwilink.c
index 827f039..50b1ee4 100644
--- a/drivers/nfc/nfcwilink.c
+++ b/drivers/nfc/nfcwilink.c
@@ -352,8 +352,6 @@ static long nfcwilink_receive(void *priv_data, struct sk_buff *skb)
struct nfcwilink *drv = priv_data;
int rc;
- nfc_dev_dbg(&drv->pdev->dev, "receive entry, len %d", skb->len);
if (!skb)
return -EFAULT;
@@ -362,6 +360,8 @@ static long nfcwilink_receive(void *priv_data, struct sk_buff *skb)
return -EFAULT;
+ nfc_dev_dbg(&drv->pdev->dev, "receive entry, len %d", skb->len);
/* strip the ST header
(apart for the chnl byte, which is not received in the hdr) */
skb_pull(skb, (NFCWILINK_HDR_LEN-1)); |
int rc;
if (!skb)
return -EFAULT;
return -EFAULT;
