net/rfkill/core.c: Avoid leaving freed data in a list
The list_for_each_entry loop can fail, in which case the list element is
not removed from the list rfkill_fds. Since this list is not accessed by
the loop, the addition of &data->list into the list is just moved after the
loop.
The sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E,E1,E2;
identifier l;
*list_add(&E->l,E1);
... when != E1
when != list_del(&E->l)
when != list_del_init(&E->l)
when != E = E2
*kfree(E);//
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
net/rfkill/core.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/rfkill/core.c b/net/rfkill/core.c
index 0198191..be90640 100644
--- a/net/rfkill/core.c
+++ b/net/rfkill/core.c
@@ -1024,7 +1024,6 @@ static int rfkill_fop_open(struct inode *inode, struct file *file)
* start getting events from elsewhere but hold mtx to get
* startup events added first
- list_add(&data->list, &rfkill_fds);
list_for_each_entry(rfkill, &rfkill_list, node) {
ev = kzalloc(sizeof(*ev), GFP_KERNEL);
@@ -1033,6 +1032,7 @@ static int rfkill_fop_open(struct inode *inode, struct file *file)
rfkill_fill_event(&ev->ev, rfkill, RFKILL_OP_ADD);
list_add_tail(&ev->list, &data->events);
+ list_add(&data->list, &rfkill_fds);
mutex_unlock(&data->mtx);
mutex_unlock(&rfkill_global_mutex); |
