net/phy: Remove return value for void function
Author: Shruti Kanetkar <Shruti@Freescale.com>
This was caught when using a spatch (aka. coccinelle) script
written by Joe Perches.
Cc: Joe Perches
Signed-off-by: Shruti Kanetkar
Signed-off-by: David S. Miller
 drivers/net/phy/at803x.c  | 3 +--
 drivers/net/phy/smsc.c    | 3 +--
 drivers/net/phy/vitesse.c | 3 +--
 3 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/net/phy/at803x.c b/drivers/net/phy/at803x.c
index b256083..6c622ae 100644
--- a/drivers/net/phy/at803x.c
+++ b/drivers/net/phy/at803x.c
@@ -253,8 +253,7 @@ static int __init atheros_init(void)
 static void __exit atheros_exit(void)
-	return phy_drivers_unregister(at803x_driver,
-				      ARRAY_SIZE(at803x_driver));
+	phy_drivers_unregister(at803x_driver, ARRAY_SIZE(at803x_driver));
 module_init(atheros_init);
diff --git a/drivers/net/phy/smsc.c b/drivers/net/phy/smsc.c
index 11f3481..180c494 100644
--- a/drivers/net/phy/smsc.c
+++ b/drivers/net/phy/smsc.c
@@ -249,8 +249,7 @@ static int __init smsc_init(void)
 static void __exit smsc_exit(void)
-	return phy_drivers_unregister(smsc_phy_driver,
-		ARRAY_SIZE(smsc_phy_driver));
+	phy_drivers_unregister(smsc_phy_driver, ARRAY_SIZE(smsc_phy_driver));
 MODULE_DESCRIPTION("SMSC PHY driver");
diff --git a/drivers/net/phy/vitesse.c b/drivers/net/phy/vitesse.c
index 14372c6..5dc0935d 100644
--- a/drivers/net/phy/vitesse.c
+++ b/drivers/net/phy/vitesse.c
@@ -319,8 +319,7 @@ static int __init vsc82xx_init(void)
 static void __exit vsc82xx_exit(void)
-	return phy_drivers_unregister(vsc82xx_driver,
-		ARRAY_SIZE(vsc82xx_driver));
+	phy_drivers_unregister(vsc82xx_driver, ARRAY_SIZE(vsc82xx_driver));
 module_init(vsc82xx_init);
BtrLinux
Privacy Overview
