net/openvswitch/flow.c: Replace rcu_dereference() with rcu_access_pointer()
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The "rcu_dereference()" call is used directly in a condition.
Since its return value is never dereferenced it is recommended to use
"rcu_access_pointer()" instead of "rcu_dereference()".
Therefore, this patch makes the replacement.
The following Coccinelle semantic patch was used:
if(
- rcu_dereference
+ rcu_access_pointer
while(
- rcu_dereference
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: David S. Miller
net/openvswitch/flow.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/openvswitch/flow.c b/net/openvswitch/flow.c
index d07ab53..7064da9 100644
--- a/net/openvswitch/flow.c
+++ b/net/openvswitch/flow.c
@@ -89,7 +89,7 @@ void ovs_flow_stats_update(struct sw_flow *flow, __be16 tcp_flags,
* allocated stats as we have already locked them.
if (likely(flow->stats_last_writer != NUMA_NO_NODE)
- && likely(!rcu_dereference(flow->stats[node]))) {
+ && likely(!rcu_access_pointer(flow->stats[node]))) {
/* Try to allocate node-specific stats. */
struct flow_stats *new_stats; |
