net/mlx5: Use PTR_ERR_OR_ZERO() to simplify the code
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR.
Generated by: scripts/coccinelle/api/ptr_ret.cocci
Signed-off-by: Wei Yongjun
Acked-by: Leon Romanovsky
Signed-off-by: David S. Miller
 drivers/net/ethernet/mellanox/mlx5/core/fs_core.c | 10 ++--------
 1 file changed, 2 insertions(+), 8 deletions(-)
diff --git a/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c b/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c
index 1a377b4..75bb8c8 100644
--- a/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c
+++ b/drivers/net/ethernet/mellanox/mlx5/core/fs_core.c
@@ -1740,10 +1740,7 @@ static int init_ingress_acl_root_ns(struct mlx5_flow_steering *steering)
 	/* create 1 prio*/
 	prio = fs_create_prio(&steering->esw_egress_root_ns->ns, 0,
 			      MLX5_TOTAL_VPORTS(steering->dev));
-	if (IS_ERR(prio))
-		return PTR_ERR(prio);
-	else
-		return 0;
+	return PTR_ERR_OR_ZERO(prio);
 static int init_egress_acl_root_ns(struct mlx5_flow_steering *steering)
@@ -1757,10 +1754,7 @@ static int init_egress_acl_root_ns(struct mlx5_flow_steering *steering)
 	/* create 1 prio*/
 	prio = fs_create_prio(&steering->esw_ingress_root_ns->ns, 0,
-	if (IS_ERR(prio))
-	else
-		return 0;
 int mlx5_init_fs(struct mlx5_core_dev *dev) |
 	/* create 1 prio*/
-	if (IS_ERR(prio))
-	else
-		return 0;
 	/* create 1 prio*/
-	if (IS_ERR(prio))
-	else
-		return 0;
