net/iucv: Add missing spin_unlock
Add a spin_unlock missing on the error path.  There seems like no reason
why the lock should continue to be held if the kzalloc fail.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* spin_lock(E1,...);
  <+... when != E1
  if (...) {
    ... when != E1
*   return ...;
* spin_unlock(E1,...);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/iucv/af_iucv.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/iucv/af_iucv.c b/net/iucv/af_iucv.c
index c8b4599..9637e45 100644
--- a/net/iucv/af_iucv.c
+++ b/net/iucv/af_iucv.c
@@ -1619,7 +1619,7 @@ static void iucv_callback_rx(struct iucv_path *path, struct iucv_message *msg)
 save_message:
 	save_msg = kzalloc(sizeof(struct sock_msg_q), GFP_ATOMIC | GFP_DMA);
 	if (!save_msg)
-		return;
+		goto out_unlock;
 	save_msg->path = path;
 	save_msg->msg = *msg;
