net/ibm/emac: fix type of phy_mode
Author: Andrzej Hajda <a.hajda@samsung.com>
phy_mode can be negative.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: David S. Miller
 drivers/net/ethernet/ibm/emac/core.h | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/ibm/emac/core.h b/drivers/net/ethernet/ibm/emac/core.h
index 28df374..f379e47 100644
--- a/drivers/net/ethernet/ibm/emac/core.h
+++ b/drivers/net/ethernet/ibm/emac/core.h
@@ -181,7 +181,7 @@ struct emac_instance {
 	struct mal_commac		commac;
 	/* PHY infos */
-	u32				phy_mode;
+	int				phy_mode;
 	u32				phy_map;
 	u32				phy_address;
 	u32				phy_feat_exc;
BtrLinux
Privacy Overview
