netfilter:ipvs: use kmemdup
Author: Shan Wei <shanwei@cn.fujitsu.com>
The semantic patch that makes this output is available
in scripts/coccinelle/api/memdup.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Shan Wei
Signed-off-by: Simon Horman
 net/netfilter/ipvs/ip_vs_pe_sip.c | 9 ++++-----
 net/netfilter/ipvs/ip_vs_sync.c   | 3 +--
 2 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/net/netfilter/ipvs/ip_vs_pe_sip.c b/net/netfilter/ipvs/ip_vs_pe_sip.c
index 0d83bc0..13d607a 100644
--- a/net/netfilter/ipvs/ip_vs_pe_sip.c
+++ b/net/netfilter/ipvs/ip_vs_pe_sip.c
@@ -92,14 +92,13 @@ ip_vs_sip_fill_param(struct ip_vs_conn_param *p, struct sk_buff *skb)
 	if (get_callid(dptr, dataoff, datalen, &matchoff, &matchlen))
 		return -EINVAL;
-	p->pe_data = kmalloc(matchlen, GFP_ATOMIC);
-	if (!p->pe_data)
-		return -ENOMEM;
 	/* N.B: pe_data is only set on success,
 	 * this allows fallback to the default persistence logic on failure
-	memcpy(p->pe_data, dptr + matchoff, matchlen);
+	p->pe_data = kmemdup(dptr + matchoff, matchlen, GFP_ATOMIC);
+	if (!p->pe_data)
+		return -ENOMEM;
 	p->pe_data_len = matchlen;
 	return 0;
diff --git a/net/netfilter/ipvs/ip_vs_sync.c b/net/netfilter/ipvs/ip_vs_sync.c
index fecf24d..c5d13b0 100644
--- a/net/netfilter/ipvs/ip_vs_sync.c
+++ b/net/netfilter/ipvs/ip_vs_sync.c
@@ -697,13 +697,12 @@ ip_vs_conn_fill_param_sync(struct net *net, int af, union ip_vs_sync_conn *sc,
 			return 1;
-		p->pe_data = kmalloc(pe_data_len, GFP_ATOMIC);
+		p->pe_data = kmemdup(pe_data, pe_data_len, GFP_ATOMIC);
 		if (!p->pe_data) {
 			if (p->pe->module)
 				module_put(p->pe->module);
 			return -ENOMEM;
-		memcpy(p->pe_data, pe_data, pe_data_len);
 		p->pe_data_len = pe_data_len;
 	return 0;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
