netfilter: nf_conntrack: remove exceptional & on function name
Author: Himangi Saraogi <himangi774@gmail.com>
In this file, function names are otherwise used as pointers without &.
A simplified version of the Coccinelle semantic patch that makes this
change is as follows:
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Pablo Neira Ayuso
 net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.c b/net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.c
index 4ce44c4..a054fe0 100644
--- a/net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.c
+++ b/net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.c
@@ -358,7 +358,7 @@ static struct nf_sockopt_ops so_getorigdst = {
 	.pf		= PF_INET,
 	.get_optmin	= SO_ORIGINAL_DST,
 	.get_optmax	= SO_ORIGINAL_DST+1,
-	.get		= &getorigdst,
+	.get		= getorigdst,
 	.owner		= THIS_MODULE,
BtrLinux
Privacy Overview
