netfilter: Deletion of unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions free_percpu() and module_put() test whether their argument
is NULL and then return immediately. Thus the test around the call is
not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Acked-by: Julian Anastasov
Acked-by: Simon Horman
Signed-off-by: Pablo Neira Ayuso
 net/netfilter/ipvs/ip_vs_ctl.c   | 3 +--
 net/netfilter/ipvs/ip_vs_pe.c    | 3 +--
 net/netfilter/ipvs/ip_vs_sched.c | 3 +--
 net/netfilter/ipvs/ip_vs_sync.c  | 3 +--
 net/netfilter/nf_tables_api.c    | 3 +--
 5 files changed, 5 insertions(+), 10 deletions(-)
diff --git a/net/netfilter/ipvs/ip_vs_ctl.c b/net/netfilter/ipvs/ip_vs_ctl.c
index ac7ba68..b8295a4 100644
--- a/net/netfilter/ipvs/ip_vs_ctl.c
+++ b/net/netfilter/ipvs/ip_vs_ctl.c
@@ -465,8 +465,7 @@ __ip_vs_bind_svc(struct ip_vs_dest *dest, struct ip_vs_service *svc)
 static void ip_vs_service_free(struct ip_vs_service *svc)
-	if (svc->stats.cpustats)
-		free_percpu(svc->stats.cpustats);
+	free_percpu(svc->stats.cpustats);
 	kfree(svc);
diff --git a/net/netfilter/ipvs/ip_vs_pe.c b/net/netfilter/ipvs/ip_vs_pe.c
index 1a82b29..0df17ca 100644
--- a/net/netfilter/ipvs/ip_vs_pe.c
+++ b/net/netfilter/ipvs/ip_vs_pe.c
@@ -37,8 +37,7 @@ struct ip_vs_pe *__ip_vs_pe_getbyname(const char *pe_name)
 			rcu_read_unlock();
 			return pe;
-		if (pe->module)
-			module_put(pe->module);
+		module_put(pe->module);
 	rcu_read_unlock();
diff --git a/net/netfilter/ipvs/ip_vs_sched.c b/net/netfilter/ipvs/ip_vs_sched.c
index 4dbcda6..199760c 100644
--- a/net/netfilter/ipvs/ip_vs_sched.c
+++ b/net/netfilter/ipvs/ip_vs_sched.c
@@ -104,8 +104,7 @@ static struct ip_vs_scheduler *ip_vs_sched_getbyname(const char *sched_name)
 			mutex_unlock(&ip_vs_sched_mutex);
 			return sched;
-		if (sched->module)
-			module_put(sched->module);
+		module_put(sched->module);
diff --git a/net/netfilter/ipvs/ip_vs_sync.c b/net/netfilter/ipvs/ip_vs_sync.c
index 7162c86..c47ffd7 100644
--- a/net/netfilter/ipvs/ip_vs_sync.c
+++ b/net/netfilter/ipvs/ip_vs_sync.c
@@ -820,8 +820,7 @@ ip_vs_conn_fill_param_sync(struct net *net, int af, union ip_vs_sync_conn *sc,
 		p->pe_data = kmemdup(pe_data, pe_data_len, GFP_ATOMIC);
 		if (!p->pe_data) {
-			if (p->pe->module)
-				module_put(p->pe->module);
+			module_put(p->pe->module);
 			return -ENOMEM;
 		p->pe_data_len = pe_data_len;
diff --git a/net/netfilter/nf_tables_api.c b/net/netfilter/nf_tables_api.c
index 1ffb253..18a9dae 100644
--- a/net/netfilter/nf_tables_api.c
+++ b/net/netfilter/nf_tables_api.c
@@ -3674,8 +3674,7 @@ static int nf_tables_abort(struct sk_buff *skb)
 			break;
 		case NFT_MSG_NEWCHAIN:
 			if (nft_trans_chain_update(trans)) {
-				if (nft_trans_chain_stats(trans))
-					free_percpu(nft_trans_chain_stats(trans));
+				free_percpu(nft_trans_chain_stats(trans));
 				nft_trans_destroy(trans);
 			} else {
BtrLinux
Privacy Overview
