netfilter: ctnetlink: fix error return code in init path
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Initialize return variable before exiting on an error path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Pablo Neira Ayuso
 net/netfilter/nf_conntrack_netlink.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/net/netfilter/nf_conntrack_netlink.c b/net/netfilter/nf_conntrack_netlink.c
index da4fc37..9807f32 100644
--- a/net/netfilter/nf_conntrack_netlink.c
+++ b/net/netfilter/nf_conntrack_netlink.c
@@ -2790,7 +2790,8 @@ static int __init ctnetlink_init(void)
 		goto err_unreg_subsys;
-	if (register_pernet_subsys(&ctnetlink_net_ops)) {
+	ret = register_pernet_subsys(&ctnetlink_net_ops);
+	if (ret < 0) {
 		pr_err("ctnetlink_init: cannot register pernet operations\n");
 		goto err_unreg_exp_subsys;
BtrLinux
Privacy Overview
