netdev/phy: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_available_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
local idexpression r.n;
expression r,e;
 for_each_available_child_of_node(r,n) {
   of_node_put(n);
   e = n
+  of_node_put(n);
?  break;
... when != n
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/phy/mdio-mux.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/net/phy/mdio-mux.c b/drivers/net/phy/mdio-mux.c
index 280c7c3..908e8d4 100644
--- a/drivers/net/phy/mdio-mux.c
+++ b/drivers/net/phy/mdio-mux.c
@@ -144,6 +144,7 @@ int mdio_mux_init(struct device *dev,
 			dev_err(dev,
 				"Error: Failed to allocate memory for child\n");
 			ret_val = -ENOMEM;
+			of_node_put(child_bus_node);
 			break;
 		cb->bus_number = v;
BtrLinux
Privacy Overview
