NetCP: Deletion of unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions cpsw_ale_destroy() and of_dev_put() test whether their argument
is NULL and then return immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: David S. Miller
drivers/net/ethernet/ti/netcp_ethss.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/net/ethernet/ti/netcp_ethss.c b/drivers/net/ethernet/ti/netcp_ethss.c
index 345cd25..84f5ce5 100644
--- a/drivers/net/ethernet/ti/netcp_ethss.c
+++ b/drivers/net/ethernet/ti/netcp_ethss.c
@@ -2011,12 +2011,10 @@ static int gbe_probe(struct netcp_device *netcp_device, struct device *dev,
quit:
if (gbe_dev->hw_stats)
devm_kfree(dev, gbe_dev->hw_stats);
- if (gbe_dev->ale)
- cpsw_ale_destroy(gbe_dev->ale);
+ cpsw_ale_destroy(gbe_dev->ale);
if (gbe_dev->ss_regs)
devm_iounmap(dev, gbe_dev->ss_regs);
- if (interfaces)
- of_node_put(interfaces);
+ of_node_put(interfaces);
devm_kfree(dev, gbe_dev);
return ret;
quit:
- if (gbe_dev->ale)
- if (interfaces)
return ret;
