net/atm: Adjust confusing if indentation
Outdent the code following an if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/atm/common.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/atm/common.c b/net/atm/common.c
index 940404a..1b9c52a 100644
--- a/net/atm/common.c
+++ b/net/atm/common.c
@@ -792,7 +792,7 @@ int vcc_getsockopt(struct socket *sock, int level, int optname,
 	default:
 		if (level == SOL_SOCKET)
 			return -EINVAL;
-			break;
+		break;
 	if (!vcc->dev || !vcc->dev->ops->getsockopt)
 		return -EINVAL;
BtrLinux
Privacy Overview
