net/ariadne: delete unneeded call to netdev_priv
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Netdev_priv is an accessor function, and has no purpose if its result is
not used.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
@@ local idexpression x; @@
-x = netdev_priv(...);
... when != x
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/amd/ariadne.c | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/drivers/net/ethernet/amd/ariadne.c b/drivers/net/ethernet/amd/ariadne.c
index b08101b..968b7bf 100644
--- a/drivers/net/ethernet/amd/ariadne.c
+++ b/drivers/net/ethernet/amd/ariadne.c
@@ -718,7 +718,6 @@ static int ariadne_init_one(struct zorro_dev *z,
 	unsigned long mem_start = board + ARIADNE_RAM;
 	struct resource *r1, *r2;
 	struct net_device *dev;
-	struct ariadne_private *priv;
 	u32 serial;
 	int err;
@@ -738,8 +737,6 @@ static int ariadne_init_one(struct zorro_dev *z,
 		return -ENOMEM;
-	priv = netdev_priv(dev);
 	r1->name = dev->name;
 	r2->name = dev->name;
BtrLinux
Privacy Overview
