net/appletalk: Remove redundant test
atif is tested for being NULL twice, with the same effect in each case.  I
have kept the second test, as it seems to fit well with the comment above it.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x@p1 == NULL || ...) { ... when forall
   return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
x@p2 == NULL
x@p2 != NULL
// another path to the test that is not through p1?
@s exists@
local idexpression r.x;
position r.p1,r.p2;
... when != x@p1
x@p2 == NULL
x@p2 != NULL
@fix depends on !s@
position r.p1,r.p2;
expression x,E;
statement S1,S2;
- if ((x@p2 != NULL) || ...)
  S1
- if ((x@p2 == NULL) && ...) S1
- BUG_ON(x@p2 == NULL);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/appletalk/ddp.c | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/net/appletalk/ddp.c b/net/appletalk/ddp.c
index c3f0027..5abce07 100644
--- a/net/appletalk/ddp.c
+++ b/net/appletalk/ddp.c
@@ -815,9 +815,6 @@ static int atif_ioctl(int cmd, void __user *arg)
 				return -EPERM;
 			if (sa->sat_family != AF_APPLETALK)
 				return -EINVAL;
-			if (!atif)
-				return -EADDRNOTAVAIL;
 			 * for now, we only support proxy AARP on ELAP;
 			 * we should be able to do it for LocalTalk, too.
BtrLinux
Privacy Overview
