net/apne: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
Author: Duan Jiong <duanj.fnst@cn.fujitsu.com>
This patch fixes coccinelle error regarding usage of IS_ERR and
PTR_ERR instead of PTR_ERR_OR_ZERO.
Signed-off-by: Duan Jiong
Signed-off-by: David S. Miller
 drivers/net/ethernet/8390/apne.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/8390/apne.c b/drivers/net/ethernet/8390/apne.c
index 30104b6..c56ac9e 100644
--- a/drivers/net/ethernet/8390/apne.c
+++ b/drivers/net/ethernet/8390/apne.c
@@ -560,9 +560,7 @@ static struct net_device *apne_dev;
 static int __init apne_module_init(void)
 	apne_dev = apne_probe(-1);
-	if (IS_ERR(apne_dev))
-		return PTR_ERR(apne_dev);
-	return 0;
+	return PTR_ERR_OR_ZERO(apne_dev);
 static void __exit apne_module_exit(void)
BtrLinux
Privacy Overview
