net: wireless: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
wl_cfg80211.c verified by compilation only.
phy/phy_cmn.c unverified.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
    when strict
return
- ret
+ C
Signed-off-by: Peter Senna Tschudin
Signed-off-by: John W. Linville
 drivers/net/wireless/brcm80211/brcmfmac/wl_cfg80211.c | 18 ++++++------------
 drivers/net/wireless/brcm80211/brcmsmac/phy/phy_cmn.c |  6 +-----
 2 files changed, 7 insertions(+), 17 deletions(-)
diff --git a/drivers/net/wireless/brcm80211/brcmfmac/wl_cfg80211.c b/drivers/net/wireless/brcm80211/brcmfmac/wl_cfg80211.c
index d8fa276..db3d848 100644
--- a/drivers/net/wireless/brcm80211/brcmfmac/wl_cfg80211.c
+++ b/drivers/net/wireless/brcm80211/brcmfmac/wl_cfg80211.c
@@ -1331,7 +1331,6 @@ static s32
 brcmf_cfg80211_leave_ibss(struct wiphy *wiphy, struct net_device *ndev)
 	struct brcmf_if *ifp = netdev_priv(ndev);
-	s32 err = 0;
 	brcmf_dbg(TRACE, "Enter\n");
 	if (!check_vif_up(ifp->vif))
@@ -1341,7 +1340,7 @@ brcmf_cfg80211_leave_ibss(struct wiphy *wiphy, struct net_device *ndev)
 	brcmf_dbg(TRACE, "Exit\n");
-	return err;
+	return 0;
 static s32 brcmf_set_wpa_version(struct net_device *ndev,
@@ -2388,7 +2387,6 @@ static s32 brcmf_inform_single_bss(struct brcmf_cfg80211_info *cfg,
 	struct cfg80211_bss *bss;
 	struct ieee80211_supported_band *band;
 	struct brcmu_chan ch;
-	s32 err = 0;
 	u16 channel;
 	u32 freq;
 	u16 notify_capability;
@@ -2438,7 +2436,7 @@ static s32 brcmf_inform_single_bss(struct brcmf_cfg80211_info *cfg,
 	cfg80211_put_bss(wiphy, bss);
-	return err;
+	return 0;
 static struct brcmf_bss_info_le *
@@ -2690,7 +2688,6 @@ brcmf_cfg80211_escan_handler(struct brcmf_if *ifp,
 	struct brcmf_cfg80211_info *cfg = ifp->drvr->config;
 	s32 status;
-	s32 err = 0;
 	struct brcmf_escan_result_le *escan_result_le;
 	struct brcmf_bss_info_le *bss_info_le;
 	struct brcmf_bss_info_le *bss = NULL;
@@ -2781,7 +2778,7 @@ brcmf_cfg80211_escan_handler(struct brcmf_if *ifp,
 				  status);
 exit:
-	return err;
+	return 0;
 static void brcmf_init_escan(struct brcmf_cfg80211_info *cfg)
@@ -3507,7 +3504,6 @@ static s32
 brcmf_parse_vndr_ies(const u8 *vndr_ie_buf, u32 vndr_ie_len,
 		     struct parsed_vndr_ies *vndr_ies)
-	s32 err = 0;
 	struct brcmf_vs_tlv *vndrie;
 	struct brcmf_tlv *ie;
 	struct parsed_vndr_ie_info *parsed_info;
@@ -3560,7 +3556,7 @@ next:
 			ie = (struct brcmf_tlv *)(((u8 *)ie) + ie->len +
 				TLV_HDR_LEN);
-	return err;
+	return 0;
 static u32
@@ -4650,7 +4646,6 @@ brcmf_bss_connect_done(struct brcmf_cfg80211_info *cfg,
 	struct brcmf_cfg80211_profile *profile = &ifp->vif->profile;
 	struct brcmf_cfg80211_connect_info *conn_info = cfg_to_conn(cfg);
-	s32 err = 0;
@@ -4676,7 +4671,7 @@ brcmf_bss_connect_done(struct brcmf_cfg80211_info *cfg,
 			  completed ? "succeeded" : "failed");
-	return err;
+	return 0;
 static s32
@@ -4768,7 +4763,6 @@ brcmf_notify_roaming_status(struct brcmf_if *ifp,
 			    const struct brcmf_event_msg *e, void *data)
-	s32 err = 0;
 	u32 event = e->event_code;
 	u32 status = e->status;
@@ -4779,7 +4773,7 @@ brcmf_notify_roaming_status(struct brcmf_if *ifp,
 			brcmf_bss_connect_done(cfg, ifp->ndev, e, true);
-	return err;
+	return 0;
 static s32
diff --git a/drivers/net/wireless/brcm80211/brcmsmac/phy/phy_cmn.c b/drivers/net/wireless/brcm80211/brcmsmac/phy/phy_cmn.c
index b0fd807..57ecc05 100644
--- a/drivers/net/wireless/brcm80211/brcmsmac/phy/phy_cmn.c
+++ b/drivers/net/wireless/brcm80211/brcmsmac/phy/phy_cmn.c
@@ -1538,11 +1538,7 @@ static s8
 wlc_user_txpwr_antport_to_rfport(struct brcms_phy *pi, uint chan, u32 band,
 				 u8 rate)
-	s8 offset = 0;
-	if (!pi->user_txpwr_at_rfport)
-		return offset;
-	return offset;
+	return 0;
 void wlc_phy_txpower_recalc_target(struct brcms_phy *pi)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
