net: thunderx: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
local idexpression r.n;
expression r,e;
 for_each_child_of_node(r,n) {
   of_node_put(n);
   e = n
+  of_node_put(n);
?  break;
... when != n
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/cavium/thunder/thunder_bgx.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/cavium/thunder/thunder_bgx.c b/drivers/net/ethernet/cavium/thunder/thunder_bgx.c
index 574c492..180aa9f 100644
--- a/drivers/net/ethernet/cavium/thunder/thunder_bgx.c
+++ b/drivers/net/ethernet/cavium/thunder/thunder_bgx.c
@@ -977,8 +977,10 @@ static int bgx_init_of_phy(struct bgx *bgx)
 		SET_NETDEV_DEV(&bgx->lmac[lmac].netdev, &bgx->pdev->dev);
 		bgx->lmac[lmac].lmacid = lmac;
 		lmac++;
-		if (lmac == MAX_LMAC_PER_BGX)
+		if (lmac == MAX_LMAC_PER_BGX) {
+			of_node_put(np_child);
 			break;
 	return 0;
BtrLinux
Privacy Overview
