net: sun4i-emac: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/ethernet/allwinner/sun4i-emac.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/allwinner/sun4i-emac.c b/drivers/net/ethernet/allwinner/sun4i-emac.c
index 1fcd556..f3470d9 100644
--- a/drivers/net/ethernet/allwinner/sun4i-emac.c
+++ b/drivers/net/ethernet/allwinner/sun4i-emac.c
@@ -850,8 +850,10 @@ static int emac_probe(struct platform_device *pdev)
db->clk = devm_clk_get(&pdev->dev, NULL);
- if (IS_ERR(db->clk))
+ if (IS_ERR(db->clk)) {
+ ret = PTR_ERR(db->clk);
goto out;
clk_prepare_enable(db->clk); |
goto out;
