net: stmmac: fix type of entry variable
Author: Andrzej Hajda <a.hajda@samsung.com>
Variable can store negative values.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: David S. Miller
 drivers/net/ethernet/stmicro/stmmac/stmmac_main.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c b/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
index 925f2f8..934143e 100644
--- a/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
+++ b/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
@@ -1945,7 +1945,7 @@ static netdev_tx_t stmmac_xmit(struct sk_buff *skb, struct net_device *dev)
 	struct stmmac_priv *priv = netdev_priv(dev);
 	unsigned int txsize = priv->dma_tx_size;
-	unsigned int entry;
+	int entry;
 	int i, csum_insertion = 0, is_jumbo = 0;
 	int nfrags = skb_shinfo(skb)->nr_frags;
 	struct dma_desc *desc, *first;
BtrLinux
Privacy Overview
