net: phy: mdio: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_available_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_available_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/phy/mdio-mux-mmioreg.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/drivers/net/phy/mdio-mux-mmioreg.c b/drivers/net/phy/mdio-mux-mmioreg.c
index 2377c13..7fde454 100644
--- a/drivers/net/phy/mdio-mux-mmioreg.c
+++ b/drivers/net/phy/mdio-mux-mmioreg.c
@@ -113,12 +113,14 @@ static int mdio_mux_mmioreg_probe(struct platform_device *pdev)
 		if (!iprop || len != sizeof(uint32_t)) {
 			dev_err(&pdev->dev, "mdio-mux child node %s is "
 				"missing a 'reg' property\n", np2->full_name);
+			of_node_put(np2);
 			return -ENODEV;
 		if (be32_to_cpup(iprop) & ~s->mask) {
 			dev_err(&pdev->dev, "mdio-mux child node %s has "
 				"a 'reg' value with unmasked bits\n",
 				np2->full_name);
+			of_node_put(np2);
 			return -ENODEV;
BtrLinux
Privacy Overview
