net: phy: at803x: fix coccinelle warnings
Author: Fengguang Wu <fengguang.wu@intel.com>
drivers/net/phy/at803x.c:196:26-32: ERROR: application of sizeof to pointer
 sizeof when applied to a pointer typed expression gives the size of
 the pointer
Generated by: scripts/coccinelle/misc/noderef.cocci
Signed-off-by: Fengguang Wu
Acked-by: Daniel Mack
Signed-off-by: David S. Miller
 drivers/net/phy/at803x.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/phy/at803x.c b/drivers/net/phy/at803x.c
index 3cbd82f..fdc1b41 100644
--- a/drivers/net/phy/at803x.c
+++ b/drivers/net/phy/at803x.c
@@ -193,7 +193,7 @@ static int at803x_probe(struct phy_device *phydev)
 	struct device *dev = &phydev->dev;
 	struct at803x_priv *priv;
-	priv = devm_kzalloc(dev, sizeof(priv), GFP_KERNEL);
+	priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL);
 	if (!priv)
 		return -ENOMEM;
BtrLinux
Privacy Overview
