net-PA Semi: Deletion of unnecessary checks before the function call “pci_dev_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Acked-by: Olof Johansson
Acked-by: Luis R. Rodriguez
Signed-off-by: David S. Miller
 drivers/net/ethernet/pasemi/pasemi_mac.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/net/ethernet/pasemi/pasemi_mac.c b/drivers/net/ethernet/pasemi/pasemi_mac.c
index 30d934d..44e8d7d 100644
--- a/drivers/net/ethernet/pasemi/pasemi_mac.c
+++ b/drivers/net/ethernet/pasemi/pasemi_mac.c
@@ -1837,10 +1837,8 @@ pasemi_mac_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	return err;
 out:
-	if (mac->iob_pdev)
-		pci_dev_put(mac->iob_pdev);
-	if (mac->dma_pdev)
-		pci_dev_put(mac->dma_pdev);
+	pci_dev_put(mac->iob_pdev);
+	pci_dev_put(mac->dma_pdev);
 	free_netdev(dev);
 out_disable_device:
