net: netcp: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
local idexpression r.n;
expression r,e;
 for_each_child_of_node(r,n) {
   of_node_put(n);
   e = n
+  of_node_put(n);
?  break;
... when != n
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/ti/netcp_ethss.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/net/ethernet/ti/netcp_ethss.c b/drivers/net/ethernet/ti/netcp_ethss.c
index 6bff8d8..4e70e75 100644
--- a/drivers/net/ethernet/ti/netcp_ethss.c
+++ b/drivers/net/ethernet/ti/netcp_ethss.c
@@ -2637,8 +2637,10 @@ static void init_secondary_ports(struct gbe_priv *gbe_dev,
 			mac_phy_link = true;
 		slave->open = true;
-		if (gbe_dev->num_slaves >= gbe_dev->max_num_slaves)
+		if (gbe_dev->num_slaves >= gbe_dev->max_num_slaves) {
+			of_node_put(port);
 			break;
 	/* of_phy_connect() is needed only for MAC-PHY interface */
@@ -3137,8 +3139,10 @@ static int gbe_probe(struct netcp_device *netcp_device, struct device *dev,
 			continue;
 		gbe_dev->num_slaves++;
+			of_node_put(interface);
 			break;
 	of_node_put(interfaces);
BtrLinux
Privacy Overview
