net: mv643xx_eth: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e, func, da;
-init_timer (&e);
+setup_timer (&e, func, da);
-e.data = da;
-e.function = func;
Signed-off-by: Vaishali Thakkar
Signed-off-by: David S. Miller
drivers/net/ethernet/marvell/mv643xx_eth.c | 9 +++------
1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/net/ethernet/marvell/mv643xx_eth.c b/drivers/net/ethernet/marvell/mv643xx_eth.c
index 1c75829..d52639b 100644
--- a/drivers/net/ethernet/marvell/mv643xx_eth.c
+++ b/drivers/net/ethernet/marvell/mv643xx_eth.c
@@ -3125,9 +3125,8 @@ static int mv643xx_eth_probe(struct platform_device *pdev)
mib_counters_clear(mp);
- init_timer(&mp->mib_counters_timer);
- mp->mib_counters_timer.data = (unsigned long)mp;
- mp->mib_counters_timer.function = mib_counters_timer_wrapper;
+ setup_timer(&mp->mib_counters_timer, mib_counters_timer_wrapper,
+ (unsigned long)mp);
mp->mib_counters_timer.expires = jiffies + 30 * HZ;
spin_lock_init(&mp->mib_counters_lock);
@@ -3136,9 +3135,7 @@ static int mv643xx_eth_probe(struct platform_device *pdev)
netif_napi_add(dev, &mp->napi, mv643xx_eth_poll, NAPI_POLL_WEIGHT);
- init_timer(&mp->rx_oom);
- mp->rx_oom.data = (unsigned long)mp;
- mp->rx_oom.function = oom_timer_wrapper;
+ setup_timer(&mp->rx_oom, oom_timer_wrapper, (unsigned long)mp);
res = platform_get_resource(pdev, IORESOURCE_IRQ, 0); |
