net: mv643xx_eth: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_available_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_available_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/marvell/mv643xx_eth.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/marvell/mv643xx_eth.c b/drivers/net/ethernet/marvell/mv643xx_eth.c
index e893a35..dfb6d5f 100644
--- a/drivers/net/ethernet/marvell/mv643xx_eth.c
+++ b/drivers/net/ethernet/marvell/mv643xx_eth.c
@@ -2817,8 +2817,10 @@ static int mv643xx_eth_shared_of_probe(struct platform_device *pdev)
 	for_each_available_child_of_node(np, pnp) {
 		ret = mv643xx_eth_shared_of_add_port(pdev, pnp);
-		if (ret)
+		if (ret) {
+			of_node_put(pnp);
 			return ret;
 	return 0;
BtrLinux
Privacy Overview
