net: ipv6: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Initialize return variable before exiting on an error path.
The initial initialization of the return variable is also dropped, because
that value is never used.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/ipv6/esp6.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/net/ipv6/esp6.c b/net/ipv6/esp6.c
index 6dc7fd3..282f372 100644
--- a/net/ipv6/esp6.c
+++ b/net/ipv6/esp6.c
@@ -167,8 +167,6 @@ static int esp6_output(struct xfrm_state *x, struct sk_buff *skb)
 	struct esp_data *esp = x->data;
 	/* skb is pure payload to encrypt */
-	err = -ENOMEM;
 	aead = esp->aead;
 	alen = crypto_aead_authsize(aead);
@@ -203,8 +201,10 @@ static int esp6_output(struct xfrm_state *x, struct sk_buff *skb)
 	tmp = esp_alloc_tmp(aead, nfrags + sglists, seqhilen);
-	if (!tmp)
+	if (!tmp) {
+		err = -ENOMEM;
 		goto error;
 	seqhi = esp_tmp_seqhi(tmp);
 	iv = esp_tmp_iv(aead, tmp, seqhilen);
BtrLinux
Privacy Overview
