net: icplus: remove unnecessary code
Author: Greg Dietsche <Gregory.Dietsche@cuw.edu>
Compile tested.
remove unnecessary code that matches this coccinelle pattern
	if (...)
		return ret;
	return ret;
Signed-off-by: Greg Dietsche
Signed-off-by: David S. Miller
 drivers/net/phy/icplus.c | 6 +-----
 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/net/phy/icplus.c b/drivers/net/phy/icplus.c
index 9a09e24..d4cbc29 100644
--- a/drivers/net/phy/icplus.c
+++ b/drivers/net/phy/icplus.c
@@ -109,11 +109,7 @@ static int ip1001_config_init(struct phy_device *phydev)
 	value = phy_read(phydev, 16);
 	value |= 0x3;
-	err = phy_write(phydev, 16, value);
-	if (err < 0)
-		return err;
-	return err;
+	return phy_write(phydev, 16, value);
 static int ip175c_read_status(struct phy_device *phydev)
BtrLinux
Privacy Overview
