net: hisilicon: fix ptr_ret.cocci warnings
Author: Wu Fengguang <fengguang.wu@intel.com>
drivers/net/ethernet/hisilicon/hns/hnae.c:442:1-3: WARNING: PTR_ERR_OR_ZERO can be used
 Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: scripts/coccinelle/api/ptr_ret.cocci
CC: Arnd Bergmann
Signed-off-by: Fengguang Wu
Signed-off-by: David S. Miller
 drivers/net/ethernet/hisilicon/hns/hnae.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/net/ethernet/hisilicon/hns/hnae.c b/drivers/net/ethernet/hisilicon/hns/hnae.c
index 9d3bb83..b364529 100644
--- a/drivers/net/ethernet/hisilicon/hns/hnae.c
+++ b/drivers/net/ethernet/hisilicon/hns/hnae.c
@@ -439,10 +439,7 @@ EXPORT_SYMBOL(hnae_ae_unregister);
 static int __init hnae_init(void)
 	hnae_class = class_create(THIS_MODULE, "hnae");
-	if (IS_ERR(hnae_class))
-		return PTR_ERR(hnae_class);
-	return 0;
+	return PTR_ERR_OR_ZERO(hnae_class);
 static void __exit hnae_exit(void)
BtrLinux
Privacy Overview
