net: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Set the return variable to propagate any error code as done elsewhere in
the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/toshiba/ps3_gelic_net.c | 18 +++++++++++-------
 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/drivers/net/ethernet/toshiba/ps3_gelic_net.c b/drivers/net/ethernet/toshiba/ps3_gelic_net.c
index f7f2ef4..d899d00 100644
--- a/drivers/net/ethernet/toshiba/ps3_gelic_net.c
+++ b/drivers/net/ethernet/toshiba/ps3_gelic_net.c
@@ -1739,12 +1739,14 @@ static int ps3_gelic_driver_probe(struct ps3_system_bus_device *dev)
 		GELIC_CARD_PORT_STATUS_CHANGED;
-	if (gelic_card_init_chain(card, &card->tx_chain,
-			card->descr, GELIC_NET_TX_DESCRIPTORS))
+	result = gelic_card_init_chain(card, &card->tx_chain,
+				       card->descr, GELIC_NET_TX_DESCRIPTORS);
+	if (result)
 		goto fail_alloc_tx;
-	if (gelic_card_init_chain(card, &card->rx_chain,
-				 card->descr + GELIC_NET_TX_DESCRIPTORS,
-				 GELIC_NET_RX_DESCRIPTORS))
+	result = gelic_card_init_chain(card, &card->rx_chain,
+				       card->descr + GELIC_NET_TX_DESCRIPTORS,
+				       GELIC_NET_RX_DESCRIPTORS);
+	if (result)
 		goto fail_alloc_rx;
 	/* head of chain */
@@ -1754,7 +1756,8 @@ static int ps3_gelic_driver_probe(struct ps3_system_bus_device *dev)
 		card->rx_top, card->tx_top, sizeof(struct gelic_descr),
 	/* allocate rx skbs */
-	if (gelic_card_alloc_rx_skbs(card))
+	result = gelic_card_alloc_rx_skbs(card);
+	if (result)
 		goto fail_alloc_skbs;
 	spin_lock_init(&card->tx_lock);
@@ -1772,7 +1775,8 @@ static int ps3_gelic_driver_probe(struct ps3_system_bus_device *dev)
 #ifdef CONFIG_GELIC_WIRELESS
-	if (gelic_wl_driver_probe(card)) {
+	result = gelic_wl_driver_probe(card);
+	if (result) {
 		dev_dbg(&dev->core, "%s: WL init failed\n", __func__);
 		goto fail_setup_netdev;
BtrLinux
Privacy Overview
