net: fec: Remove unneeded use of IS_ERR_VALUE() macro
Author: Fabio Estevam <fabio.estevam@freescale.com>
There is no need to use the IS_ERR_VALUE() macro for checking
the return value from pm_runtime_* functions.
Just do a simple negative test instead.
The semantic patch that makes this change is available
in scripts/coccinelle/api/pm_runtime.cocci.
Signed-off-by: Fabio Estevam
Signed-off-by: David S. Miller
 drivers/net/ethernet/freescale/fec_main.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/freescale/fec_main.c b/drivers/net/ethernet/freescale/fec_main.c
index ca79236..d8e07bb 100644
--- a/drivers/net/ethernet/freescale/fec_main.c
+++ b/drivers/net/ethernet/freescale/fec_main.c
@@ -1779,7 +1779,7 @@ static int fec_enet_mdio_read(struct mii_bus *bus, int mii_id, int regnum)
 	int ret = 0;
 	ret = pm_runtime_get_sync(dev);
-	if (IS_ERR_VALUE(ret))
+	if (ret < 0)
 		return ret;
 	fep->mii_timeout = 0;
@@ -1818,7 +1818,7 @@ static int fec_enet_mdio_write(struct mii_bus *bus, int mii_id, int regnum,
 	int ret = 0;
+	if (ret < 0)
 		return ret;
@@ -2870,7 +2870,7 @@ fec_enet_open(struct net_device *ndev)
 	int ret;
 	ret = pm_runtime_get_sync(&fep->pdev->dev);
+	if (ret < 0)
 		return ret;
 	pinctrl_pm_select_default_state(&fep->pdev->dev);
BtrLinux
Privacy Overview
