net: ep93xx_eth: Delete unnecessary checks before the function call “kfree”
Author: Markus Elfring <elfring@users.sourceforge.net>
The kfree() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: H Hartley Sweeten
Signed-off-by: David S. Miller
 drivers/net/ethernet/cirrus/ep93xx_eth.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/net/ethernet/cirrus/ep93xx_eth.c b/drivers/net/ethernet/cirrus/ep93xx_eth.c
index 3a12c09..de9f7c9 100644
--- a/drivers/net/ethernet/cirrus/ep93xx_eth.c
+++ b/drivers/net/ethernet/cirrus/ep93xx_eth.c
@@ -475,8 +475,7 @@ static void ep93xx_free_buffers(struct ep93xx_priv *ep)
 		if (d)
 			dma_unmap_single(dev, d, PKT_BUF_SIZE, DMA_FROM_DEVICE);
-		if (ep->rx_buf[i] != NULL)
-			kfree(ep->rx_buf[i]);
+		kfree(ep->rx_buf[i]);
 	for (i = 0; i < TX_QUEUE_ENTRIES; i++) {
@@ -486,8 +485,7 @@ static void ep93xx_free_buffers(struct ep93xx_priv *ep)
 		if (d)
 			dma_unmap_single(dev, d, PKT_BUF_SIZE, DMA_TO_DEVICE);
-		if (ep->tx_buf[i] != NULL)
-			kfree(ep->tx_buf[i]);
+		kfree(ep->tx_buf[i]);
 	dma_free_coherent(dev, sizeof(struct ep93xx_descs), ep->descs,
BtrLinux
Privacy Overview
