net: davinci_emac: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Propagate error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/ti/davinci_emac.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/ti/davinci_emac.c b/drivers/net/ethernet/ti/davinci_emac.c
index aeebc0a..a21c77b 100644
--- a/drivers/net/ethernet/ti/davinci_emac.c
+++ b/drivers/net/ethernet/ti/davinci_emac.c
@@ -2004,8 +2004,10 @@ static int davinci_emac_probe(struct platform_device *pdev)
 	if (res_ctrl) {
 		priv->ctrl_base =
 			devm_ioremap_resource(&pdev->dev, res_ctrl);
-		if (IS_ERR(priv->ctrl_base))
+		if (IS_ERR(priv->ctrl_base)) {
+			rc = PTR_ERR(priv->ctrl_base);
 			goto no_pdata;
 	} else {
 		priv->ctrl_base = priv->remap_addr + pdata->ctrl_mod_reg_offset;
BtrLinux
Privacy Overview
