net: cavium: liquidio: Return correct error code
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
The return value of vmalloc on failure of allocation of memory should
be -ENOMEM and not -1.
Found using Coccinelle. A simplified version of the semantic patch
used is:
expression *e;
identifier l1;
position p,q;
e@q = vmalloc(...);
if@p (e == NULL) {
goto l1;
l1:
return -1
+ -ENOMEM
Signed-off-by: David S. Miller
 drivers/net/ethernet/cavium/liquidio/lio_main.c    | 2 +-
 drivers/net/ethernet/cavium/liquidio/octeon_droq.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/ethernet/cavium/liquidio/lio_main.c b/drivers/net/ethernet/cavium/liquidio/lio_main.c
index 8727655..ac0394c 100644
--- a/drivers/net/ethernet/cavium/liquidio/lio_main.c
+++ b/drivers/net/ethernet/cavium/liquidio/lio_main.c
@@ -1683,7 +1683,7 @@ static int octeon_setup_droq(struct octeon_device *oct, int q_no, int num_descs,
 	dev_dbg(&oct->pci_dev->dev, "Creating Droq: %d\n", q_no);
 	/* droq creation and local register settings. */
 	ret_val = octeon_create_droq(oct, q_no, num_descs, desc_size, app_ctx);
-	if (ret_val == -1)
+	if (ret_val < 0)
 		return ret_val;
 	if (ret_val == 1) {
diff --git a/drivers/net/ethernet/cavium/liquidio/octeon_droq.c b/drivers/net/ethernet/cavium/liquidio/octeon_droq.c
index 4dba86e..174072b 100644
--- a/drivers/net/ethernet/cavium/liquidio/octeon_droq.c
+++ b/drivers/net/ethernet/cavium/liquidio/octeon_droq.c
@@ -983,5 +983,5 @@ int octeon_create_droq(struct octeon_device *oct,
 create_droq_fail:
 	octeon_delete_droq(oct, q_no);
-	return -1;
+	return -ENOMEM;
