net: bnx2x: Change variable type to bool
Author: Peter Senna Tschudin <peter.senna@gmail.com>
The variable rc is only assigned the values true and false.
The function bnx2x_prev_is_path_marked already returns bool.
Change rc type to bool.
The simplified semantic patch that find this problem is as
follows (http://coccinelle.lip6.fr/):
@exists@
type T;
identifier b;
- T
+ bool
b = ...;
... when any
b = \(true\|false\)
Signed-off-by: Peter Senna Tschudin
Signed-off-by: David S. Miller
drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
index 10c8fdb..13a5694 100644
--- a/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
+++ b/drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
@@ -9879,7 +9879,7 @@ static int bnx2x_prev_path_mark_eeh(struct bnx2x *bp)
static bool bnx2x_prev_is_path_marked(struct bnx2x *bp)
struct bnx2x_prev_path_list *tmp_list;
- int rc = false;
+ bool rc = false;
if (down_trylock(&bnx2x_prev_sem))
return false; |
- int rc = false;
+ bool rc = false;
return false;
