neigh: remove exceptional & on function name
Author: Himangi Saraogi <himangi774@gmail.com>
In this file, function names are otherwise used as pointers without &.
A simplified version of the Coccinelle semantic patch that makes this
change is as follows:
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: David S. Miller
net/ipv6/ndisc.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/ipv6/ndisc.c b/net/ipv6/ndisc.c
index b7ece27..339078f 100644
--- a/net/ipv6/ndisc.c
+++ b/net/ipv6/ndisc.c
@@ -1768,7 +1768,7 @@ int __init ndisc_init(void)
#ifdef CONFIG_SYSCTL
err = neigh_sysctl_register(NULL, &nd_tbl.parms,
- &ndisc_ifinfo_sysctl_change);
+ ndisc_ifinfo_sysctl_change);
if (err)
goto out_unregister_pernet;
out: |
if (err)
out:
