myri10ge: Delete an unnecessary check before the function call “kfree”
Author: Markus Elfring <elfring@users.sourceforge.net>
The kfree() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: David S. Miller
 drivers/net/ethernet/myricom/myri10ge/myri10ge.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/ethernet/myricom/myri10ge/myri10ge.c b/drivers/net/ethernet/myricom/myri10ge/myri10ge.c
index 71af98b..1412f5a 100644
--- a/drivers/net/ethernet/myricom/myri10ge/myri10ge.c
+++ b/drivers/net/ethernet/myricom/myri10ge/myri10ge.c
@@ -4226,8 +4226,7 @@ static void myri10ge_remove(struct pci_dev *pdev)
 		mtrr_del(mgp->mtrr, mgp->iomem_base, mgp->board_span);
 #endif
 	myri10ge_free_slices(mgp);
-	if (mgp->msix_vectors != NULL)
-		kfree(mgp->msix_vectors);
+	kfree(mgp->msix_vectors);
 	dma_free_coherent(&pdev->dev, sizeof(*mgp->cmd),
 			  mgp->cmd, mgp->cmd_bus);
BtrLinux
Privacy Overview
