mtd: ts5500_flash: avoid calling map_destroy on NULL
map_destroy dereferences its argument. The call is furthermore only
reachable when this argument is NULL. Thus the call is dropped.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression *x;
*if (x == NULL)
* map_destroy(x);
return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
drivers/mtd/maps/ts5500_flash.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/drivers/mtd/maps/ts5500_flash.c b/drivers/mtd/maps/ts5500_flash.c
index e2147bf..e02dfa9 100644
--- a/drivers/mtd/maps/ts5500_flash.c
+++ b/drivers/mtd/maps/ts5500_flash.c
@@ -94,7 +94,6 @@ static int __init init_ts5500_map(void)
return 0;
err1:
- map_destroy(mymtd);
iounmap(ts5500_map.virt);
err2:
return rc; |
return 0;
err1:
err2:
return rc;
