mtd: simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
 drivers/mtd/devices/elm.c    | 5 -----
 drivers/mtd/nand/txx9ndfmc.c | 4 +---
 2 files changed, 1 insertion(+), 8 deletions(-)
diff --git a/drivers/mtd/devices/elm.c b/drivers/mtd/devices/elm.c
index 4f683d2..d1dd6a3 100644
--- a/drivers/mtd/devices/elm.c
+++ b/drivers/mtd/devices/elm.c
@@ -368,11 +368,6 @@ static int elm_probe(struct platform_device *pdev)
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!res) {
-		dev_err(&pdev->dev, "no memory resource defined\n");
-		return -ENODEV;
 	info->elm_base = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(info->elm_base))
 		return PTR_ERR(info->elm_base);
diff --git a/drivers/mtd/nand/txx9ndfmc.c b/drivers/mtd/nand/txx9ndfmc.c
index 440b570..235714a 100644
--- a/drivers/mtd/nand/txx9ndfmc.c
+++ b/drivers/mtd/nand/txx9ndfmc.c
@@ -281,12 +281,10 @@ static int __init txx9ndfmc_probe(struct platform_device *dev)
 	unsigned long gbusclk = plat->gbus_clock;
 	struct resource *res;
-	res = platform_get_resource(dev, IORESOURCE_MEM, 0);
-	if (!res)
-		return -ENODEV;
 	drvdata = devm_kzalloc(&dev->dev, sizeof(*drvdata), GFP_KERNEL);
 	if (!drvdata)
 		return -ENOMEM;
+	res = platform_get_resource(dev, IORESOURCE_MEM, 0);
 	drvdata->base = devm_ioremap_resource(&dev->dev, res);
 	if (IS_ERR(drvdata->base))
 		return PTR_ERR(drvdata->base);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
