mtd: Remove redundant spi driver bus initialization
Author: Lars-Peter Clausen <lars@metafoo.de>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
identifier _driver;
struct spi_driver _driver = {
	.driver = {
-		.bus = &spi_bus_type,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
 drivers/mtd/devices/m25p80.c        | 1 -
 drivers/mtd/devices/mtd_dataflash.c | 1 -
 drivers/mtd/devices/sst25l.c        | 1 -
 3 files changed, 3 deletions(-)
diff --git a/drivers/mtd/devices/m25p80.c b/drivers/mtd/devices/m25p80.c
index 884904d..7c60ddd 100644
--- a/drivers/mtd/devices/m25p80.c
+++ b/drivers/mtd/devices/m25p80.c
@@ -992,7 +992,6 @@ static int __devexit m25p_remove(struct spi_device *spi)
 static struct spi_driver m25p80_driver = {
 	.driver = {
 		.name	= "m25p80",
 		.owner	= THIS_MODULE,
 	.id_table	= m25p_ids,
diff --git a/drivers/mtd/devices/mtd_dataflash.c b/drivers/mtd/devices/mtd_dataflash.c
index d75c7af..236057e 100644
--- a/drivers/mtd/devices/mtd_dataflash.c
+++ b/drivers/mtd/devices/mtd_dataflash.c
@@ -936,7 +936,6 @@ static int __devexit dataflash_remove(struct spi_device *spi)
 static struct spi_driver dataflash_driver = {
 	.driver = {
 		.name		= "mtd_dataflash",
 		.of_match_table = dataflash_dt_ids,
diff --git a/drivers/mtd/devices/sst25l.c b/drivers/mtd/devices/sst25l.c
index d38ef3b..e45f62e 100644
--- a/drivers/mtd/devices/sst25l.c
+++ b/drivers/mtd/devices/sst25l.c
@@ -444,7 +444,6 @@ static int __devexit sst25l_remove(struct spi_device *spi)
 static struct spi_driver sst25l_driver = {
 	.driver = {
 		.name	= "sst25l",
 	.probe		= sst25l_probe,
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
