mtd: onenand: samsung: add missing iounmap
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Add missing iounmap in error handling code, in a case where the function
already preforms iounmap on some other execution path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e;
statement S,S1;
int ret;
e = \(ioremap\|ioremap_nocache\)(...)
... when != iounmap(e)
if (<+...e...+>) S
... when any
when != iounmap(e)
*if (...)
{ ... when != iounmap(e)
return ...; }
... when any
iounmap(e);
Signed-off-by: Julia Lawall
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
drivers/mtd/onenand/samsung.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c
index fa1ee43..deaf762 100644
--- a/drivers/mtd/onenand/samsung.c
+++ b/drivers/mtd/onenand/samsung.c
@@ -923,7 +923,7 @@ static int s3c_onenand_probe(struct platform_device *pdev)
r = platform_get_resource(pdev, IORESOURCE_MEM, 1);
if (!r) {
dev_err(&pdev->dev, "no buffer memory resource defined\n");
- return -ENOENT;
+ err = -ENOENT;
goto ahb_resource_failed;
@@ -964,7 +964,7 @@ static int s3c_onenand_probe(struct platform_device *pdev)
if (!r) {
dev_err(&pdev->dev, "no dma memory resource defined\n");
- return -ENOENT;
+ err = -ENOENT;
goto dma_resource_failed;
if (!r) {
- return -ENOENT;
+ err = -ENOENT;
if (!r) {
- return -ENOENT;
+ err = -ENOENT;
