mtd: nandsim: add __init attribute
Author: Julia Lawall <julia.lawall@lip6.fr>
Add __init attribute on functions that are only called from other __init
functions and that are not inlined, at least with gcc version 4.8.4 on an
x86 machine with allyesconfig.  Currently, the functions are put in the
.text.unlikely segment.  Declaring them as __init will cause them to be
put in the .init.text and to disappear after initialization.
The result of objdump -x on the functions before the change is as follows:
000000000000059a l     F .text.unlikely 0000000000000239 alloc_device
000000000000034e l     F .text.unlikely 000000000000002e get_partition_name
00000000000007d3 l     F .text.unlikely 00000000000005da init_nandsim
And after the change it is as follows:
0000000000000029 l     F .init.text	0000000000000234 alloc_device
0000000000000000 l     F .init.text	0000000000000029 get_partition_name
000000000000025d l     F .init.text	00000000000005d5 init_nandsim
Done with the help of Coccinelle.  The semantic patch checks for local
static non-init functions that are called from an __init function and are
not called from any other function.
Signed-off-by: Julia Lawall
Signed-off-by: Boris Brezillon
 drivers/mtd/nand/nandsim.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/nandsim.c b/drivers/mtd/nand/nandsim.c
index 6ff1d8d..66eebb9 100644
--- a/drivers/mtd/nand/nandsim.c
+++ b/drivers/mtd/nand/nandsim.c
@@ -569,7 +569,7 @@ static void nandsim_debugfs_remove(struct nandsim *ns)
  * RETURNS: 0 if success, -ENOMEM if memory alloc fails.
-static int alloc_device(struct nandsim *ns)
+static int __init alloc_device(struct nandsim *ns)
 	struct file *cfile;
 	int i, err;
@@ -654,7 +654,7 @@ static void free_device(struct nandsim *ns)
-static char *get_partition_name(int i)
+static char __init *get_partition_name(int i)
 	return kasprintf(GFP_KERNEL, "NAND simulator partition %d", i);
@@ -664,7 +664,7 @@ static char *get_partition_name(int i)
  * RETURNS: 0 if success, -ERRNO if failure.
-static int init_nandsim(struct mtd_info *mtd)
+static int __init init_nandsim(struct mtd_info *mtd)
 	struct nand_chip *chip = mtd_to_nand(mtd);
 	struct nandsim   *ns   = nand_get_controller_data(chip);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
