mtd: nand: sunxi: add missing of_node_put
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Acked-by: Chen-Yu Tsai
Acked-by: Boris Brezillon
Signed-off-by: Brian Norris
 drivers/mtd/nand/sunxi_nand.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/sunxi_nand.c b/drivers/mtd/nand/sunxi_nand.c
index 2ed52e4..1bbcc0c 100644
--- a/drivers/mtd/nand/sunxi_nand.c
+++ b/drivers/mtd/nand/sunxi_nand.c
@@ -1391,8 +1391,10 @@ static int sunxi_nand_chips_init(struct device *dev, struct sunxi_nfc *nfc)
 	for_each_child_of_node(np, nand_np) {
 		ret = sunxi_nand_chip_init(dev, nfc, nand_np);
-		if (ret)
+		if (ret) {
+			of_node_put(nand_np);
 			return ret;
 	return 0;
BtrLinux
Privacy Overview
